CamaroZ28.Com Message Board
-   -   Pcv (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/pcv-457039/)
TransAmGT94 Jun 20, 2006 04:35 PM
Pcv
When i did a motor swap i bought the egr block off kit which came with the egr system block off and the pcv valve block off. When i started it up i smokes from the valve covers. do i have to run a pcv valve or can i leave it blocked off and vent a different way? it is killing the car at idle when i run it. need help plz. Thanks
chris
TransAmGT94 Jun 20, 2006 04:43 PM
Re: Pcv
sorry i was looking at the wrong thing the kit blocked all egr stuff so why am i not venting?
mebanditws6 Jun 20, 2006 05:06 PM
Re: Pcv
From you what you told me on the phone, I bet it could simply be a stuck PCV valve. Try that first before ditching the breathers. It shouldn't hurt having extra means of venting off crankcase pressure. Ben's 454SS bolt on smog motor did fine with 2 breathers.;)
Jason
Injuneer Jun 20, 2006 05:28 PM
Re: Pcv
Do you still have the vent line from the throttle body to the valve cover attached and functioning? Do you have the PCV valve in place on the drivers side of the intake, and the U-shaped tube connected to the vacuum port?
TransAmGT94 Jun 20, 2006 07:33 PM
Re: Pcv
Yes to all the above its getting another pcv maybe that will fix it. The PCV sticks a little. Any other ideas?
TransAmGT94 Jun 20, 2006 08:36 PM
Re: Pcv
car idles like it is missfiring but seams to clear up when i pull the breather out and let the fumes vent from the valve covers. Maybe it is killing it self.
Injuneer Jun 21, 2006 09:55 AM
Re: Pcv
So you have a breather AND the line from the TB to the valve cover installed? Why would the breather not let the fumes vent? That's the purpose of an open breather. Confusing.
TransAmGT94 Jun 21, 2006 06:34 PM
Re: Pcv
Ok the second pcv fixed the problem now im have a whole new problem with the alt. im going to start a new thread for it
