CamaroZ28.Com Message Board
-   -   Pcm....??? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/pcm-268428/)
blind527 Jun 3, 2004 12:55 PM
Pcm....???
where do i find this, how do i take it out????
i wanna get it reprogrammed and such, and i doubt my car is driveable w/o one...
i have a 97 formula
1msfyter Jun 3, 2004 01:06 PM
Passenger side under the black window cowl. 2 10mm bolts and it oulls straight up.
blind527 Jun 3, 2004 01:07 PM
so i can access it through the outside of the car???
is the car driveable w/o it? i wouldn't think so, thanks though
1msfyter Jun 3, 2004 01:10 PM
Its under the hood. If you remove it the car is dead. 2 ways to do it. Buy another PCM from madz28.com so you can still drive your car while its being sent to you. Or do the exchange . You buy tuning and pay a core charge. He will send the new pcm to you and you send back the old one. ION at www.madz28.com is the man to order from.
1msfyter Jun 3, 2004 01:13 PM
PCM location upper left corner the gray box. I hide all my wires to clean the engine bay.
http://www.fasterbaby.com/pcm2.jpg
blind527 Jun 3, 2004 01:17 PM
maybe ill just buy another one....i can tell him the VIN number and everything and he can make everything better, correct??? what is the cost difference between exchanging and buying a new one?
1msfyter Jun 3, 2004 01:20 PM
You can tune your OBD2 or do the OBD1 conversion. You get more horsepower from the conversion and less problems(SES lights)The OBD1 conversion is $226 I think complete. And you own the PCM. Just fill out the checklist of all your mods. You'll notice a difference.
blind527 Jun 3, 2004 01:26 PM
so what your saying is if i convert to OBD1, ill have less problems, and better results???? to conver to that, i wouldn't need to purchase anything extra right??? its all in the PCM?
1msfyter Jun 3, 2004 01:42 PM
You will need a LT4 knock module $35-40. It helps with the false knock. The OBD1 conversion ignores the rear O2's and the crank shaft position sensor. After that its a simple 10 min plug and play operation.
blind527 Jun 3, 2004 01:45 PM
ok cool, i only asked that because it says on the site:
$225 -- OBDII to OBDI Conversion Kit for all 96-97 LT1s. Absolutely Plug and Play! Includes a modified OBDI PCM to work with your OBDII knock sensor(s) and custom programming. Free updates for a period of 3 months after the initial purchase (you pay only return shipping) then $40 plus shipping afterwards.
after seeing that i didn't know if i need something else
93transam1234 Jun 3, 2004 01:47 PM
I would check and see if a OBD1 PCM will work with your emissions facility, I know here in MD they plug a computer into your cars PCM adapter. I dont know if you switched to OBD1 if that would efect what would happen.
1msfyter Jun 3, 2004 01:47 PM
You still need the LT4 knock module. He might have some in stock.
blind527 Jun 3, 2004 01:48 PM
sweet man, thanks for your help ill contact him about that
