CamaroZ28.Com Message Board
-   -   pacesetter gaskets (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/pacesetter-gaskets-368724/)
KillWhitey May 19, 2005 09:42 PM
pacesetter gaskets
I got my lt's yesterday and am going to put them on Monday on my day off and I was wondering if yall used the gaskets that they sent with the kit or did yall spend a little more money on a set of good gaskets? Will it hurt to use the ones with the kit?? And what did yall use for gaskets??
Tim
fredmr39 May 19, 2005 09:44 PM
Re: pacesetter gaskets
Don't use what they come with - though some have had success using the paper gaskets they supply AND a copper RTV supplement. It's good insurance to purchase some Felpro 1406s, etc..do a search, you will find lots of info!
steves97z28 May 19, 2005 09:49 PM
i have fel pro's and have had no problems
KillWhitey May 19, 2005 09:52 PM
So i should put in a order for the copper gaskets?? Do i need to use rtv with those?
Tim
cb94ta May 19, 2005 09:53 PM
I was a cheap ass and used the ones with the kit and I've been rewarded with a great set of leaks, and now I get to buy some better gaskets and go through putting them on, woohooo!!!!!!!!!
KillWhitey May 19, 2005 10:11 PM
I see. So i will put in the order in the morning for the copper ones and do it right the first time. I have already spent over a grand on new parts. What is another 20 or 30 gonna hurt. Its gonna be a busy weekend.
Tim
med_reject May 19, 2005 10:40 PM
burned paper gaskets are not fun to scrape off the heads in the f-body engine compartment.
Some people found copper gaskets too stiff to seal properly and have had resultant leaks. I've had felpro 1406's for years with my hooker shorties (after blowing 2 sets of paper ones) and they have been good to me.
KillWhitey May 22, 2005 10:46 AM
Got the 1406's and got the headers on. The only issue was getting the car high enough. Once i did they slid right in from the bottom. Special tool....8x8x12 concrete blocks to put under the jack and jack stands. It was actually a pretty easy job.
Tim
DiabloGT May 22, 2005 12:05 PM
does anyone have a link for those better gaskets for where to buy them?
TransAm9585 May 22, 2005 12:13 PM
Summit Racing has the FEL-1406 as the part number fairly decent price also.
89385formula May 22, 2005 12:42 PM
Wow, i must be the only idiot here that used the gaskets that came with the Pacesetters. "knock On Wood", but so far they have worked really good. No leaks whatsoever. I ran em for a bit and tightened the bolts again hot, and seems to working good so far. I'll have the heads off soon for the LE2 kit, then I will probably upgrade.
KillWhitey May 22, 2005 12:44 PM
Any auto parts store can get them. I called the local little store here in bellville and they came by 2 pm. I would also check out the hardware store there and pick up 6 8x8x12 concrete blocks. That is unless you have a lift to work with.
Tim
Birdman7389 May 22, 2005 02:09 PM
I used the paper ones included, with a coat of copper seal on both sides. Leak free since october.......
KillWhitey May 22, 2005 02:56 PM
Well now I am done. I just got them all bolted up. After i got them in there I stopped. It was like getting to the top of a hill. I got there and took a break. Got a fresh start this afternoon and got it all together. some of the bolts were not too easy to get to. Im glad i finally got the headers. I have been talking about it for about 2 years now.
Tim
