P0300 Misfire
Old Apr 14, 2003 | 04:10 PM
claws1ata's Avatar
Angry P0300 Misfire
I have got a random multi misfire on my 1996 LT1 Z28. I have changed spark plugs, wires, optispark dist, cap & rotor. I have changed injectors as well. Installed new EGR valve and cannot find a vacuum leak. I have still got a misfire on #2. The car runs bad under a load levels out when cruising. The analyzer shows that the misfire comes and goes. Anyone with any other ideas would be greatly appreciated.
Old Apr 14, 2003 | 04:30 PM
Camaro_SS/R's Avatar
Is #2 misfiring a lot more than the other and why?
Do you have a bigger cam in the engine?
Did you replace the whole optispark, brand new? I'm not sure reading "optispark dist, cap & rotor" Did you hook up the vent and blowing tube to the opti correctly.
Have you check your coil?
good luck
Old Apr 14, 2003 | 08:45 PM
claws1ata's Avatar
Angry P0300 Misfire
The engine is still factory stock. #2 is misfiring the most. You can feel it pick up and drop out. The optispark dist was changed as well as cap and rotor button. Any ideas as to the cause?
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
Schul365
Aug 22, 2015 10:00 AM
Girrrrl
Aug 20, 2015 09:26 AM
zajones
Jul 30, 2015 02:18 PM
