Overheating when AC is on........
Old May 1, 2007 | 12:25 PM
Kurt Crosbie's Avatar
Whats the deal with this? If I'm sitting still, it goes up between the 3/4 mark and the red zone. Even when I'm not sitting still, the water still gets hotter than when the AC is off. Why does the temperature go up when the AC is on?
Old May 1, 2007 | 12:41 PM
rickreeves1's Avatar
On most cars the AC condenser is located in front of the radiator. The air passing through it hits the radiator next. The warmer air may be whats raising the temperature. The fans are also programmed to come on with the AC but my temps have always still gone up with the AC on even when I had the stock PCM program and stock cooling system.
Old May 1, 2007 | 01:54 PM
neil350's Avatar
Shouldnt, the ac should trigger the fans
Old May 1, 2007 | 05:18 PM
92_RSCamaro's Avatar
Your fan switch for the a/c to kick on the fans may be out or not working properly. Also a lower temp thermostat and fan switch to kick the fans on would not hurt.
Old May 1, 2007 | 07:46 PM
ayers1967's Avatar
I had to have my radiator boiled to clean out the lime build up in it. It fixed the problem.
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
Noct
Jul 14, 2015 01:18 AM
thenewkid
Jul 2, 2015 07:16 AM
warmeck
Apr 16, 2015 05:50 PM
