Overheating! Please Help!!
Old Sep 26, 2004 | 10:13 AM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Ok, so the car just randomly started overheating tonight and the low coolant light came on. I check the coolant level and it is like half empty..... So i fill it up and the temp comes down some but it still sits quite a bit over 210(half)... I tried to bleed the valve but when i opened it up nothing came out... I mean NOTHING. No AIR, No COOLANT, no NOTHING.. Is this weird??? When I opened up the radiator cap there was plenty of pressure and coolant came spewing out, but right after, when i open the bleeder valve, NOTHING... WTF is going on???? I suspect the water pump but it has already been replaced like 30K ago... Maybe the WP?? Any imput appreciated. Thanks.
Chris
Old Sep 26, 2004 | 10:20 AM
n2ceptor's Avatar
Re: Overheating! Please Help!!
Radiator Cap?????
Old Sep 26, 2004 | 11:41 AM
indieaz's Avatar
sounds to me like your radiator cap is no good and there isn't enough pressure in the system.
Old Sep 26, 2004 | 11:29 PM
Yep, thanks guys. It is the radiator cap. Um, what kind do I get to replace it? Just a factory one?
Old Sep 27, 2004 | 01:01 PM
Nevermind..... Upon further examination during the daytime i can clearly see a crack in the radiator just under the cap.. I thought it was the cap because i heard a gurgling coming from that area... but it was the crack below it.... So now my question shifts to... What kind of radiator to replace with?? I dont want to go stock again, i would like to go with a nice aftermarket one... Any suggestions guys?? Thanks.
Chris
Old Sep 27, 2004 | 02:56 PM
n2ceptor's Avatar
Stock should be fine.... But if you want aftermarket, check here...
http://web.camaross.com/forums/showthread.php?t=301956
Old Sep 27, 2004 | 03:43 PM
Heatmaker's Avatar
Advanced Member
Niether... you should throw it out and get an intercooler.....
You'll need the Turbokit to go with it of course...
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
Noct
Jul 14, 2015 01:18 AM
thenewkid
Jul 2, 2015 07:16 AM
warmeck
Apr 16, 2015 05:50 PM
