Overheating
Overheating
My low coolant light is back on after I replaced the thermostat yesterday, I now notice the car is back to over heating, but now I see coolant laying underneath my car. I've added coolant and water to it, yet it continues to overheat. I try to bleed the system off, but now nothing comes out of either bleeder screws. What the hell is going on?!?!?!
do your coolant fans come on? try looking closer to see where the leak is coming from. when the motor is warm do you see coolant flowing when the rad cap is off? also when the bleader screws are open and nothing is comming out, it may be air just wait and see if antifreeze is comming out. do you have a bad head gasket? is there water in the oil? how bout white smoke from the exhaust when the motor is warm. it could be a number of things but check these first
I do have smoke from the exhaust, but only at WOT. I recently did a TB Bypass, and thats when the overheating problems occured, the hose I re-routed the coolant with is kinked, could this be the problem?
I never rerouted my lines, I just took them out so you need to see where this coolant is leaking from, if it's near the firewall you have a bad heatercore, sometimes it leaks outside the compartment instead of in, run the car on jacks but be careful obviously, and see where it's coming from.
Noct
Jul 14, 2015 01:18 AM
warmeck
Apr 16, 2015 05:50 PM
