Over Opti, any alternatives.
To say the least I have had more than my share of problems from the opti set up on my car. What alternative is there out there. Can you do a intake swap and use a Distributor on a LT1 car? I am just really wanting to get away from the opti set up all together, I would greatly appritiate any input.
This subject has been beaten to death in the recent weeks. There are 2 known alternatives. One from a company that charges $500 for a better "GUARANTEED not to fail opti and another set up where you have a coil per cylinder rather than a distributor.
I suppose before i'll do that i'll just build a older style set up and go with a carb and distributor.
I forgot the second method costs around $8000, not including installation.
Originally posted by Trans AM 22502 set up where you have a coil per cylinder rather than a distributor. |
Originally posted by LALT1 I suppose before i'll do that i'll just build a older style set up and go with a carb and distributor. |
That was my next question, can this be done?:confused:
Originally posted by Trans AM 22502 I forgot the second method costs around $8000, not including installation. The LTCC is around $400, and I paid $115 for my 8 LS1 coils off a wrecked 2002 Z28. You'll also need a set of cut-to-length LS1 spark plug wires.. I'll have around $600 in mine. |
Try this 8-page thread.... might help you out:
http://web.camaross.com/forums/showt...threadid=23617 |
