CamaroZ28.Com Message Board
-   -   over heating (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/over-heating-751233/)
wildracer May 5, 2010 03:46 PM
over heating
ok guys so far this site has helped me alot with all my z28 problems...
so heres the new one ... my z keeps over heating... i checked both radiador and the little tank on the side ..there all good to go.. i ran the car and waited for the fan to kick on but never did... i let the car get to as high as 210 and still never kicked on... so i unplugged the fan and ran a by pass and the fan does work... so what and where do i start to look at how to fix this.... thanks for all your help guys..
moparman May 5, 2010 03:56 PM
210 is to low for the fans to come on. IIRC, the first fan won't come on until around 226, and the second around 235. Both should come on when the AC is turned on.
wildracer May 5, 2010 04:07 PM
wow that seems to me a little high.... i forgot to add that my car is a 97 z28 30th dont know if that makes a differance but thanks
shoebox May 5, 2010 04:25 PM
Nope, 226° is the factory setting for low speed fans to engage.
wildracer May 5, 2010 04:43 PM
ok i let the car run for about 20min... temp went up well over 210 on the gauge in fact it hit the line before the red line and still no fans...
shoebox May 5, 2010 06:53 PM
You need to hook up a scanner and look at the temps on it and see if the fans are being commanded on.
