CamaroZ28.Com Message Board
-   -   ovc wire looms (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/ovc-wire-looms-533170/)
snareman Jul 20, 2007 10:39 AM
ovc wire looms
I was told that I could drill out the ovc wire looms to fit my msd 8.5 wires. anyone know what size bit I need?
Severous01 Jul 20, 2007 10:55 AM
8.5mm
that's it...
or you can just match up some of the spare wire with spare drill bits till you get it right.
WhyHelloOfficer Jul 20, 2007 02:25 PM
I'm using the Moroso Wire Separators, they're cheap and universal to fit all plug wires 7mm - 9mm --
Summit Part No. MOR-72161
http://plaza.ufl.edu/jblazina/Pside1.jpg
Spllouder Jul 20, 2007 03:08 PM
are the wire separators mounted to anything , could i see more pics ?
how much did the wires cost are those unaversail msd wire kit ?
WhyHelloOfficer Jul 20, 2007 04:30 PM
Here is a close-up of the Passenger side:
http://plaza.ufl.edu/jblazina/Pside2.jpg
The wires and separators I purchased from a local speed shop for about $100. It is a specific LT1 Kit, but all the wires you have to cut and terminate yourself.
The separators aren't mounted to anything, literally I'm using them to keep everything organized. However, I zip-tied them all over to keep them in place while cruising.
I am also using the Taylor High Temp Silicone Heat Sleeves.
What more pictures do you need? It is extremely straight forward. The driver's side I only have the plug wires for the last two cylinders going up and over, it was easiest to run the first two straight underneath because it'd keep them further away from the header primaries.
http://plaza.ufl.edu/jblazina/Dside.jpg
Spllouder Jul 20, 2007 08:02 PM
Thanks for the info . Iam doing this all very soon . :bow:
