Out of curiosity...CC306 + 1.7 rockers = ?
Old Feb 26, 2004 | 12:17 PM
Type_O_Negative_1320's Avatar
I'm looking at getting a larger cam than I have now (currently a 218/224 0.495"/0.503") to bleed off some compression down low with my new setup. I'm looking at possibly using a CC306 instead. I have a set of 1.6 rockers and a set of 1.7 rockers that I can use. I also have a set of K800 valve springs installed that are good up to 0.700" lift.
Lift numbers with the CC306:
0.544"/0.576" with 1.6 rockers
0.578"/0.612" with 1.7 rockers
Just out of curiosity, if I decided to use the 1.7 rockers with the CC306, would it be worth it, or should I just stick with the 1.6 rockers? The heads are stock (will be smoothed out a touch before they go back on), so I'm assuming there's a point where more lift becomes less beneficial. Any opinions, or am I just plain nuts?
Old Feb 26, 2004 | 12:21 PM
red_warrior_z28's Avatar
sorry for barging in on your post but if you decide to go with the 1.7's would you consider selling your 1.6's. if so how much let me know, im looking for a good set of 1.6 for my LT1. also what brand are they
Old Feb 26, 2004 | 12:23 PM
They're LT4 rockers...but a buddy of mine local already has dibs on them if I don't use them. I'll let you know if I don't use them and if he backs out.
Old Feb 26, 2004 | 12:33 PM
RealQuick's Avatar
Re: Out of curiosity...CC306 + 1.7 rockers = ?
I would tend to think its not worth it if your not gonna have fully ported heads. Stock heads get turbulent above .55o" I believe, so why add more lift when the flow stalls.
RE AND CHERYL's Avatar
Cool
I wouldn't use the 1.7 rockers unless your heads flow well above .600. Seeing as even most ported LT1 heads are about stalled out at that point, they would most likely be a waste.
my 2 cents worth
Old Feb 26, 2004 | 01:26 PM
That's pretty much what I figured. I guess I'll stick to the 1.6s if I end up with the 306 and sell the 1.7s.
Old Feb 26, 2004 | 02:35 PM
ibanez6rg's Avatar
I would think that is too much lift. Would piston to valve clearence be an issue?
Old Feb 26, 2004 | 02:59 PM
Possibly...if I were to go that route, I'd clay it first to make sure nothing touches. I'm still debating on keeping my current cam...I need some better inputs for my compression calculator to make sure everything will be OK. It's not taking a couple of things into account, so I might be able to get by with the cam I have now.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
