Order of the rockers/valves?
Old Jun 2, 2004 | 03:38 PM
TigerWoodsJr's Avatar
Im sorry to post this stupid question, but I need to adjust my rockers and have read through shoebox's page(which rules btw) and searched the site but the easiest question of them all still escapes me.
I only need to do the drivers side, but knowing both would help. What is the cylinder order? Which is the intake and which is the exhaust valve? Like looking at the valve cover on the drivers side from the side of the car? Also the passenger side would be good to know. sorry for the silly question but I can't find the info anywhere. Thanks.
Old Jun 2, 2004 | 03:40 PM
BackInBlackZ28's Avatar
If you are ajusting the rockers you can just pull the fuse for the injectors and turn the motor over, and ajust the ones that are up , then turn it over some more and ajust the rest. Thats the easiest way ive found to do it....
Old Jun 2, 2004 | 03:50 PM
Mtrhds94Z's Avatar
Front to rear drivers side is 1-3-5-7 .. psgr side it's 2-4-6-8
Valves are: cyl#1: Ex-In- #3:In- Ex-#5:Ex-In-#7:In -Ex
Psgr side is:cyl#2: Ex-In- #4:In- Ex-#6:Ex-In-#8:In -Ex
Old Jun 2, 2004 | 03:59 PM
sweet, thank you very much.
Old Jun 2, 2004 | 04:28 PM
RamAir95TA's Avatar
Look at the rocker that is right above the header primary if you're unsure.
n2oblkz
Oct 22, 2015 02:31 PM
Stephen68
Oct 16, 2015 03:50 PM
n2oblkz
Oct 12, 2015 01:53 AM
Bxlt1
Sep 29, 2015 03:18 PM
