CamaroZ28.Com Message Board
-   -   opti spark ? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/opti-spark-138315/)
hot936spd Jun 26, 2003 01:40 PM
opti spark ?
i think my opti is going bad. should i replace it with an vented opti or should i just get a regualr one like i have?, would a vented opi make any diff? and is it more expensive? what all would i have to do? just drill a hold in my intake elblow, for the little hose? help please. plus later down the road i might put a cam in it. do vented optis, run better or last longer or something?
Injuneer Jun 26, 2003 01:42 PM
A vented Opti actually costs less. Problem is, you can't put a vented Opti on a 93 unless you change a bunch of stuff, like the timing cover, cam sprocket, cam, etc.
Vented Opti Conversion
