CamaroZ28.Com Message Board
-   -   opti questions (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/opti-questions-336955/)
AlmostfastLT1 Jan 30, 2005 12:44 PM
opti questions
I have an 94 LT1 and I converted to the 95 opti and I am using the 94 opti, do i need a 95 opti harness or am I good. I am not getting any ignition.
Thanks Mark Tisdale
Guest47904 Jan 30, 2005 01:45 PM
Re: opti questions
cammed_aro Z28 Jan 30, 2005 01:54 PM
Re: opti questions
I did the same conversion, i needed a 95 timing chain cover and the plug that goes into the distributer is longer, it is a 3$part at your local dealer, you just have to pull the pins out of your old plug and put them into the new one, its a pain in the a$$ but it only takes a few minutes. i didnt have spark at first either and i started getting pissed and then my dad unplugged the opti and put a flash light in there and said, "that hole looks a little deep for that plug"
RE AND CHERYL Jan 30, 2005 02:18 PM
Re: opti questions
The harness going to the Opti is different on the vented units.
AlmostfastLT1 Jan 30, 2005 03:08 PM
Re: opti questions
OMG!!!!!!!!!!!!!!!! dude the 94 harness is too short, omg after all the testing geeeeeeeeeeeeeeeeeeee.
Thanks guys
