opti plug?
Old Oct 17, 2004 | 04:13 PM
Jeffs94Z28's Avatar
opti plug?
http://www.technologyorgasm.com/upload/optiplug.gif Where does the circled plug wire go to? I know it has to be right infront of me somehwhere.... thanks
Old Oct 17, 2004 | 04:16 PM
ShawnMacAnanny's Avatar
Re: opti plug?
Coil maybe? Haven't dealt with my opti yet so I'm not sure.
Old Oct 17, 2004 | 04:30 PM
Josh-'04 GTO's Avatar
Re: opti plug?
Yep. Coil wire connection.
Old Oct 17, 2004 | 04:38 PM
Jeffs94Z28's Avatar
Re: opti plug?
where is the connection?
Old Oct 17, 2004 | 04:40 PM
simple's Avatar
Re: opti plug?
not sure what you mean ? but circled that pic is the connection for the coil wire
unless you mean you cant see it when everything is installed on the car?
find your coil on the front of the drivers side head follow the coil wire coming off it, it should go up and over the driver side of the water pump then down into the opti. it is a very tight fit in there and can be hard to see and get too with everything in the way
Old Oct 17, 2004 | 04:41 PM
Jeffs94Z28's Avatar
Re: opti plug?
i mean where exactly does the plug go to?
Old Oct 17, 2004 | 04:48 PM
Jeffs94Z28's Avatar
Re: opti plug?
everything is off the car for the opti replacement
Old Oct 17, 2004 | 04:59 PM
simple's Avatar
Re: opti plug?
ok then? with the opti installed on the car, that plug (the coil connection on the opti) should be at about the 1 o'clock position, just like the picture shows!
if i'm not answering your question, could you be more specific?!
Old Oct 17, 2004 | 05:01 PM
Jeffs94Z28's Avatar
Re: opti plug?
i think the question is so simple you guys don't know what im asking. do you have a picture of where the wire connected to on the non-opti side of the connection?
Old Oct 17, 2004 | 05:05 PM
simple's Avatar
Re: opti plug?
it connects to the coil pack that is mounted to the front of the drivers side head
if you are looking at you car from the front (dead center) look to the right at the drivers side head, there will be a coilpack sitting there with some ground wires and a ground strap and some electrical connections for the coil that is bolted down to the front of the head
it will have a little module behind it with some cooling fins on it.
Old Oct 17, 2004 | 05:06 PM
simple's Avatar
Re: opti plug?
thanks to shoebox, he has a picture of what i am talking about
http://shbox.com/1/coil_loc.jpg
that red thing is the coil, the lower part of the red thing with the nipple is what the coil wire comes off of and connects the coil to the opti spark!
Old Oct 17, 2004 | 05:10 PM
Jeffs94Z28's Avatar
Re: opti plug?
thats simple, i thought it was that all along, but the damn thing wont attach to it, thats why i was so baffled. perhaps i need to push the boot up so the metal thing inside of it is further back?
Old Oct 17, 2004 | 05:13 PM
simple's Avatar
Re: opti plug?
you dont have the wire backwards do you? the opti end of the coil will only attach to the opti
Old Oct 17, 2004 | 05:17 PM
Jeffs94Z28's Avatar
Re: opti plug?
i have an elbow type boot and a straight boot on the other side the straight boot goes on the opti side?
Old Oct 17, 2004 | 05:19 PM
simple's Avatar
Re: opti plug?
Yes
