CamaroZ28.Com Message Board
-   -   OK to use heat... (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/ok-use-heat-262192/)
ibanez6rg May 16, 2004 10:58 AM
OK to use heat...
without the A/C charged? As long as I have it on heat the clutch won't engage for the A/C at all, will it? Just don't want to screw it up!
I haven't had it charged since I did my heads/cam swap.
Josh'95Z28conv May 16, 2004 12:41 PM
Without the correct pressure in the ac system, the clutch shouldnt enguage anyway. You wont have any problems:)
Spinner May 16, 2004 12:50 PM
What he said. The compressor wont turn on without freon. It's a self-protection mechanism
