oil sensor going out?
Old Aug 28, 2005 | 08:56 PM
crAzy95z28's Avatar
my car has 112k. Do oil sensors go out around that time?
its been going on and off every so often.
let me know.
Old Aug 28, 2005 | 11:22 PM
OBE1 95Z28's Avatar
Re: oil sensor going out?
I don't believe oil sensors are a common failure item. They are easy to damage when you replace the tranny or engine (Up against the firewall). They're not expensive; double check that the harness isn't damaged.
Old Aug 29, 2005 | 05:41 AM
crAzy95z28's Avatar
what is the one that is in the OIL pan?
Old Aug 29, 2005 | 05:44 AM
crAzy95z28's Avatar
odd thing is.. my low oil light is coming on, but my oil is not low at all on the dipstick!
i also put in a LS1 dip stick and it is actually a bit longer (1-2) inches, but it goes way over the full mark on it so i know it cant be low on oil.
Randy
Old Aug 29, 2005 | 12:24 PM
OBE1 95Z28's Avatar
The pan sensor is the oil level sensor; this lights the dash light for low oil level.
Old Aug 29, 2005 | 05:18 PM
crAzy95z28's Avatar
that sensor could go out right?
Old Aug 29, 2005 | 05:23 PM
turbo_Z's Avatar
It can. The pressure sensor is on the back of the block. The level sensor is in the side of the pan on the drivers side.
Old Aug 29, 2005 | 06:07 PM
crAzy95z28's Avatar
cause that sensor on the pan is pretty dirty!!
maybe needs a clean or replaced huh?
if replaced how in the hell you take that thing out?
HectorM52
Jul 30, 2017 11:46 AM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
captcorvette
Mar 7, 2015 12:37 PM
Jul 4, 2005 05:00 PM
