Oil pump white spring
Old Jun 7, 2005 | 02:03 PM
xxsaint69x's Avatar
Can i get a high pressure spring at a place like autozone or napa or carquest?
Anyone has a part number?
Old Jan 14, 2007 | 10:00 PM
Steve in Seattle's Avatar
GM white Spring: 3848911
Oil Pump Spring (3848911)
Oil Pressure in small-block and V6/90º Chevrolet engines is regulated by a spring in the oil pump cover. This spring (color-coded white) produces approximately 70 psi oil pressure. Small Image Technical Notes: Used in high-performance oil pump P/N 3848907. Minimum recommended oil pressure for off-highway use is 65 psi at engine operating speed.
GM LIST: $3.91
GM Parts Direct: $2.32 + S&H
Old Jan 14, 2007 | 10:32 PM
Unless they sell GM parts, no.
Old Feb 1, 2007 | 07:38 AM
kgkern01's Avatar
How much increase in pressure should one expect with changing to the white spring over stock?
Old Feb 1, 2007 | 10:21 AM
Did you read the description posted above for an idea? Pressure has a lot to do with bearing clearances, so not everyone will see the same. Expect, roughly, at least a 10 psi increase. Could be more.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
