CamaroZ28.Com Message Board
-   -   Oil Pump Drive Question.. Help.... (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/oil-pump-drive-question-help-295504/)
Ucantcme57 Aug 26, 2004 02:49 PM
Originally Posted by MrDude_1
not to hijack your thread, but heres my problem with that:
im running a modified LT1 intake, and one of the benifits i wanted was no hole in the rear of the intake for a distrib.....
but i suppose i have to make one anyway. :(
the best idea i could come up with is a LT1 oil pump drive that mounted to a piece of billet... the billet then reached up towards the china wall.. id have to drill a hole in my block thru the china wall (two actually) and mount it thru thoes holes....
since this is my oil pump, thats kind of a big risk. :( not to mention im drillin in my motor, and its already assembled...
Send emails to: MrDude_1@excite.com
streetbad Aug 26, 2004 04:38 PM
Re: Oil Pump Drive Question.. Help....
Are you installing a conventional distributer?
