oil pump drive ?? please help
i'm installing a cam and i took the oil pump drive off to pull out the cam and the gear in it looks worn ?? by saying worn i meaning the the teeth are real thin is that normal or should i replace it any info or a part # would be appreciated. thanks:rolleyes:
