Oil pressure is very slowly dropping over time
Old Nov 21, 2006 | 11:08 PM
speed_demon24's Avatar
I could swear my oil pressure is very slowly dropping over time, now at ~35psi cruising where it used to barley be over 40psi. Should I be worried? I'm hoping I'm just being paranoid, its a stock 96k mile bottom end. I got it up to 4k rpm's to to see the oil pressure and it was still under 40psi.
Old Nov 21, 2006 | 11:27 PM
reamo04's Avatar
add in some lucas oil on your next change, i have a 145k stock bottom end, and the oil pressure had increased with the stabalizer added
Old Nov 22, 2006 | 09:44 AM
z28trick's Avatar
i wouldnt use lucas. heres why http://www.bobistheoilguy.com/images/lucas/lucas.htm
Old Nov 22, 2006 | 10:45 AM
BUBBA's Avatar
Could be your oil is a bit too thin---switch to 10W-40 Dino Oil (good quality) and see if it brings your pressure up a bit.JMHO
Old Nov 22, 2006 | 11:59 AM
T/A-Bob's Avatar
Whenever I get my oil (and filter) changed, the pressure goes back up by a few PSI. Maybe that's all you need?
Old Feb 5, 2007 | 08:56 PM
Bersaglieri's Avatar
What was the ending to this story? Rebuild or just new oil?
-Dustin-
Old Feb 5, 2007 | 09:41 PM
Cars still running, its actually running stronger than ever. I guess I just got the oil hot somehow and thats why the pressure showed lower than normal. Its about ~20-22 idle, and 38-40 cruising hot.
Old Feb 7, 2007 | 03:59 PM
Mine runs about that hot, but what about WOT? Thats when mine seems to stay the same, I'm thinking its the cheap oil I'm using the break in the cam..
-Dustin-
Old Feb 7, 2007 | 04:10 PM
-Dustin-
I haven't looked at the oil pressure at 6k+ rpm's Ill try to next time I drive it. I'm running 5w30 Mobil 1 btw.
Old Feb 7, 2007 | 05:24 PM
mrmint69's Avatar
I get 18 at idle when its warmed up. I went to a little thicker oil and it helped some.
HectorM52
Jul 30, 2017 11:46 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
