oil pressure sender
Old Mar 22, 2004 | 12:35 PM
blazzinbird's Avatar
oil pressure sender
i was told that i can put my autometer oil pressure sender in the block. someone said there is a place for it by the oil filter.
any one have any pics of this?
Old Mar 22, 2004 | 12:42 PM
97Camaro007's Avatar
I think that it's behind the intake on top of the block......i'll find a picture of it...
Old Mar 22, 2004 | 12:44 PM
http://shbox.com/1/oil_pressure_sensor.jpg unless your car is a 93 then it should be located here.....
Old Mar 22, 2004 | 12:46 PM
i know about that one, but on my 96 rob said there is also a fitting but capped ff by the oil filter
Old Mar 22, 2004 | 12:48 PM
there is a oil level sensor down by the oil filter.....http://shbox.com/1/low_oil_sensor.jpg
don't know about anything else down there
Old Mar 22, 2004 | 12:57 PM
this is what fred "injunier" wrote
Not sure how the oil pressure sensor works... If it's a resistance device that is supplied a bias voltage... e.g. like the MAP or TPS sensors(3-wire) you can run two gauges in parallel. But if its a 2-wire resistance device you need a second sensor. What year is your car? 94 and up have a plugged tap in the block right above the oil filter that can be used for an oil pressure sensor, or a line direct to a mechanical pressure gauge. That's where miine is connected
Old Mar 22, 2004 | 03:07 PM
Look under the label "Digits 10-17 of VIN". Remove that plug and you can put your additional oil pressure line there.
Old Mar 22, 2004 | 04:51 PM
is this the plug you are talking about
also does the sensor just screw right in?
http://www.mainstreamtopics.com/meme.../block_vin.jpg
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
KYWes
Apr 15, 2015 05:48 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
