Oil Pick-Up Very Loose In Pump + Checking Clearcne To Pan??
Old Jul 19, 2008 | 07:50 PM
ENRKyle20's Avatar
I am gettin very close to button up this motor im working on. Its prety exciting.. Anyway. I am installing the oil pickup. and its very loose in the pump.. actually, it was not on the pump when I took the pan off in the start of the build.. So, my question is has anyone ever used some kind of epoxy or somehting there?. or maybe a bolt or somehting?.. what are my option.. Maybe a new one?.. I dont want to go that way, but if I have to I have to. I do have the tool to install it but its installed up to the bump and I can pull it out by hand..
Also, My book tells me to measure oil can clearence? you kidding me?..im using a stock pan.. so does someone have a picture of a measurment that will tell me where it needs to be.. Thanks
Old Jul 19, 2008 | 10:24 PM
Granite00's Avatar
With the pick up that loose it will suck air. I'd invest in a new one. To check clerance, you put some clay about 3/4" tall on the pick up and put the pan on. No gasket, just push it down. Pull the pan back off and you can see how close the pick up is to the bottom of the pan. Add about 1/8" for the gasket.
Old Jul 19, 2008 | 10:26 PM
ENRKyle20's Avatar
how close is ok?.. and does anyone have a pn for the pickup?
Old Jul 19, 2008 | 10:35 PM
Pickup part number will vary depending on what pump you have. There are some stock p/ns on my Tech Page. Your pickup should be new.
3/8"-1/2" from the bottom of the pan seems to be the norm.
Old Jul 19, 2008 | 10:38 PM
ENRKyle20's Avatar
M155 HV is what the pump says. is that stock?.. or is that a Melling High Volume?
looks like maybe:
Mfg. Part No. Price (MSRP)
38-OIL PICK-UP
5.7L 1995 - 1997 12550042 $17.84
Old Jul 19, 2008 | 11:05 PM
looks like maybe:
38-OIL PICK-UP
Don't use that pump with a stock pan. That is a 3/4" High Volume pump. Not needed in most cases. Can cause problems with sucking stock pan dry and shorten oil pump drive life. It also has a weak casting.
12550042 is the p/n for a stock 3/4" pickup.
A Melling 10554 would be a better choice. There have been countless threads about pumps.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
