CamaroZ28.Com Message Board
-   -   oil drive? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/oil-drive-824402/)
twistedbowtie Jul 31, 2011 11:03 PM
oil drive?
I pulled the intake off my lt1 today and the oil pump drive I'm not sure the correct term but its the drive that looks to run offf the camshaft that slides in the block in the same spot as the distributor would go on a old sbc. Anyways back to the point the plastic on the top is broke and want to replace it. Anyone have a part number or link to where I can find it? I've looked on summit ,autozone and a few other places and can't find it. Any help will be appriciated thanks
Injuneer Jul 31, 2011 11:37 PM
Re: oil drive?
Shoebox shows:
1993-1997 oil pump drive assy - 1103868
http://shbox.com/ci/oil_pump_drive.jpg
I think someone may make an upgraded replacement.
[EDIT] found this one.... pricey though.
https://www.herronperformance.com/st...&productId=317
twistedbowtie Jul 31, 2011 11:53 PM
Re: oil drive?
Thanks alott man. Yea that is pricey. I'm running the cc306 with a bigger oil pump not sure the specs on it but its not that extreamly big. Do u think I could get by with a stock replacement?
Procharged94Lt1 Aug 1, 2011 02:21 AM
Re: oil drive?
I have the stock replacement with my car...no problems yet at all even with the high pressure spring in the pump.
shoebox Aug 1, 2011 08:09 AM
Re: oil drive?
What do you mean by "bigger"? HV pumps are known to contribute to early failure due to wear of the gear on the oil pump drive. What does the gear look like?
twistedbowtie Aug 1, 2011 10:09 AM
Re: oil drive?
thanks aswell, do you mean what does the oil gear look like? if so its the same one in the link
thanks allot for the help everyone
RamAir95TA Aug 1, 2011 12:02 PM
Re: oil drive?
Rob is asking if there is any abnormal wear on the gear, like it's been chewed up.
shoebox Aug 1, 2011 12:33 PM
Re: oil drive?
Yeah, you can see I already know what one looks like. :D
I want to know how the wear on yours looks. ;)
twistedbowtie Aug 1, 2011 01:43 PM
Re: oil drive?
Yea my fault man i couldn't understand why u wouldn't know what it looks like. Haha . But mine looks in perfect shape except at the top where it bolts down the plastic busted. I would post a pic but don't have a camera at the moment. Thanks again guys. I've got a used one I found in a old lt1 block I had in the shop but I don't wanna use it and it break on me going down the road. I can't decide wether it'll be fine or if I should buy a new. Any thoughts on that?
WS Sick Aug 2, 2011 08:10 PM
Re: oil drive?
Ive used the stock OP drive with HV pumps, HV high pressure pumps, and high pressure std vol pumps iwth no drive gear problems. I would look to the cam or installation if they are getting eaten.
twistedbowtie Aug 2, 2011 10:11 PM
Re: oil drive?
thanks man, but its not the gear getting chewed its the plastic at the top where it bolts down that busted. maybe my turque wrench is off.
but thanks to everyone for the help and addvise
