Oil cooler?
Old Jul 30, 2007 | 09:55 PM
MICKEY's Avatar
Oil cooler?
Could i take the two water supply lines that go to the oil cooler THAT ARE CAPED OFF NOW and run them to a sep. radiator, I have a heat exchanger/ rad that is 27"x12"XI" with 1/2 npt fittings on it.
Trying to get the car to run cooler.
p.s. 94 camaro s-400-88 turbo...
thanks....
Old Jul 30, 2007 | 09:58 PM
I don't see why you could not try it.
Old Jul 30, 2007 | 10:00 PM
red1997blazer's Avatar
sure you could. but, if you hook them both up to a radiator you'll have no flow going through it.
MICKEY's Avatar
IS the pres. on the pump side or rad. side?
Old Jul 30, 2007 | 10:02 PM
MICKEY's Avatar
how would i need to do it , How dose it flow with the cooler installed then?
Old Jul 30, 2007 | 10:08 PM
good question. I don't know for sure. I assume it would be the pump. Look at an exploded view of the pump to tell you for sure.
Old Jul 30, 2007 | 10:33 PM
JP95ZM6's Avatar
You could plumb the second radiator in series, between the pump and the cooler, and that would give your oil cooler colder coolant. Thus lowering your oil temperature. But, if you put the extra radiator in front of the existing one, your coolant temp may actually increase due to the extra air resistance, and the extra heat you are putting into the air & coolant from the oil. Plus, you don't want to overcool the oil, it needs to get hot enough to drive moisture out. However, if you put the extra radiator downstream from the oil cooler, you won't affect oil temperatures much, but you will add capacity to the coolant cooling system. If you want to try this, that's the configuration I recommend.
Old Jul 31, 2007 | 04:06 PM
MICKEY's Avatar
Im not using the oil cooler any more, just looking to cool the water a little better.
Noct
Jul 14, 2015 01:18 AM
Jul 10, 2015 02:23 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
