Occational rough idle
Old May 13, 2004 | 09:38 PM
Z28Boss's Avatar
Hey guys, what would make my car idle rough every once in a while. Sometimes it will run as smooth as it can get, and sometimes it is shaking pretty good. I changed my opti about a year ago, I have replaced my IAT sensor, cleaned my TB, cleaned my IAC valve, and have cleaned off my MAF. None of these things fixed it at all. Any ideas. Would bad plugs or a bad wire do this. I cant see why it only does it sometimes.
Old May 13, 2004 | 10:00 PM
ChickenScreamer94's Avatar
me too, i think mine is the opti or o2's.
but who really knows, i am just gonna start raping things till i find it...
Old May 13, 2004 | 10:11 PM
DonHood's Avatar
Re: Occational rough idle
I had sorta the same symptoms as you, but had a check engine light too. I got my ScanMaster in the mail the other day, hooked it up, and saw my O2's are shot.
ScanMaster = coolest toy ever.
Old May 14, 2004 | 01:47 AM
med_reject's Avatar
intermittent problem, more likely sensor, and o2 sensor gives lights, and causes u to change from closed to open loop if its bad enough.
Old May 14, 2004 | 04:23 PM
Z28Boss's Avatar
I have had no lights though. Its just sometimes the car runs rough at idle but with even the lightest throttle it goes away. I cant figure this one out.
Old May 14, 2004 | 11:59 PM
med_reject's Avatar
do u have an auto or manual? if its a manual, then it iwll feel rough even in gear when you are diving it.
if its an auto, it iwll feel rough at idle, and and speeds above 50mph (OD) when the torque converter locks up
Old May 15, 2004 | 01:49 PM
Z28Boss's Avatar
I have an auto trans. The problem never shows up anywhere through the power band or any other time except idle. Its just occasional rough idle when I am at lights. Dont know what else to tell ya. I just thought maybe someone has had this happen and would know what it would be.
Boss002
Jan 20, 2016 12:17 PM
Firechicken350
Aug 30, 2015 06:59 AM
michaelzilinski
Jul 31, 2015 08:41 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
