OBDI Conversion
Re: OBDI Conversion
Originally posted by ollie-99
Do i need to switch up the knock sensor when im switchin from OBDII to OBDI
if i dont switch it what kinda problems am i lookin @?
-Oliver
-Oliver
whoever does your comversion get the to put the resistor in the pcm and you dont have to change it and if you go back to obd2 pcm (for emisions if you have that where your at) you can just plug in your old pcm with no trouble.
get madwolf to do it. he did mine and he is great to deal with.
I did some searching and found that a 3.9ohm resistor is soldiered(sp) to pin 22 or 23 ( don't have notes here close by), then also connected to a ground. Sounds pretty simple. You may be able to do a search in the Computer Diagnostic section for the correct pin to attach the resistor.
I have not done this yet, but will be soon. I did buy a pcm the other day.
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
tdigger9899
Sep 7, 2015 10:56 AM
