OBDI conversion
rob,
you can add a resistor to it our just buy one from madz28 or pcmforless. you need the resistor work work with the knock sensor, it changed when gm switched over to obdii.
or change the knock sensor to an obdi style
other than that just plug it in and turn the key
93 technically is OBD1. If you are talking about changing it to an 8051 94/95 PCM style you would need a 94/95 wiring harness, the PCM, and a MAF sensor to make it work.
