OBDI conversion
Old Feb 22, 2004 | 06:59 PM
97WRAITH's Avatar
OBDI conversion
What is involved in the conversion.If I bought a OBDI pcm can I do the mod to work on my '97 ?
Rob.
Old Feb 22, 2004 | 09:03 PM
steve40's Avatar
rob,
you can add a resistor to it our just buy one from madz28 or pcmforless. you need the resistor work work with the knock sensor, it changed when gm switched over to obdii.
or change the knock sensor to an obdi style
other than that just plug it in and turn the key
Old Feb 22, 2004 | 09:17 PM
97WRAITH's Avatar
Steve do you know how to do this? I don't really want to pay another $175 US and trade mine in that I spent $175 US on already.
Rob.
Old Feb 23, 2004 | 04:26 PM
steve40's Avatar
do you have a obdi pcm already
i've seen a how to somewhere on the net
Old Feb 23, 2004 | 04:29 PM
97WRAITH's Avatar
I posted on the local board for one.Will one from an automatic car work?
Rob.
Old Feb 23, 2004 | 04:33 PM
steve40's Avatar
any one will work, you would just have to have it programmed and add the resistor if not done already
Old Feb 23, 2004 | 04:42 PM
97WRAITH's Avatar
So you know the value of the resistor and where it goes?Thanks.
Rob.
Old Feb 23, 2004 | 05:17 PM
steve40's Avatar
i never did save that page, maybe shoebox or brent would know
Old Feb 24, 2004 | 10:57 PM
94IMPALASS's Avatar
Drop me an email and I can let you know what resistor values to use and where to solder them in if you would like to do the conversion yourself.
Thans,
Bryan
Old Feb 25, 2004 | 08:19 AM
street demon2k3's Avatar
since you guys are on the subject, how hard is it to convert a 93 t/a to OBD1? whats involved with it, like hardware, programing and all that ****?
Old Feb 25, 2004 | 10:24 AM
94IMPALASS's Avatar
93 technically is OBD1. If you are talking about changing it to an 8051 94/95 PCM style you would need a 94/95 wiring harness, the PCM, and a MAF sensor to make it work.
Old Feb 25, 2004 | 10:50 AM
rage889's Avatar
Do you need the harness because 93 is batch fire and 94+ are sequential or is it for the MAF sensor? If its just the MAF sensor I would think you would be able to run the 94+ PCM in speed density mode. I can't think of any other reason the 93 harness wouldn't work besides the connectors at that point.
Old Feb 25, 2004 | 11:03 AM
94IMPALASS's Avatar
All the connectors at the PCM are completly different as well.
Old Feb 25, 2004 | 11:57 AM
Brent94Z's Avatar
Super Moderator
I'll help out by saying to just listen to what 94IMPALASS says.
Old Feb 25, 2004 | 04:47 PM
steve40's Avatar
ok, i'm confused now, is it just the plugs on the 93 harness that are different or manual and auto.
when i converted i just ordered on fron bryan
