CamaroZ28.Com Message Board
-   -   Obd1 dowloadable software?? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/obd1-dowloadable-software-890103/)
ledfootz28 Aug 29, 2024 11:12 AM
Trying to read code on 94 Z. Found my old connecting obd1 cable just need to know what software is everyone using these days that i can download on laptop??.
Injuneer Aug 29, 2024 11:28 AM
Re: Obd1 dowloadable software??
Scan94/95:
https://www.camaroz28.com/forums/com...95-lt1-874306/
https://www.camaroz28.com/forums/com...-guide-886891/
ledfootz28 Aug 29, 2024 01:36 PM
Thanks fred just downloaded program on laptop and noticed my old cable has a 9 pin serial port end. Of couse my newer laptop doesnt have this port so looking to get a new usb obd1 port cable now to run the scan.
ledfootz28 Aug 29, 2024 01:44 PM
Fred does the obd1 store ses light codes. My light came on few seconds then stayed off a couple times driving now. Will i be able to still read whatever code it threw if light is currently off??
Injuneer Aug 29, 2024 06:13 PM
Should remain in volatile memory until the vehicle has completed a specific number of “drive cycles” without the fault recurring. You can find more info about each code and what happens in the factory service manual. If you don’t have a factory service manual, free download here:
https://www.mediafire.com/?40mfgeoe4ctti
If battery backup power to the PCM is lost, even for a few seconds, volatile memory will be lost. Don't disconnect a battery cable, or pull the “PCM BAT” fuse.
ledfootz28 Aug 29, 2024 07:27 PM
Ok thanks i ll order a cable asap and wont drive it hoping to pull code it threw. I ll keep thread updated once i find out more info
BellaFoster Sep 10, 2024 07:24 AM
I am just posting so I can keep track of this thread.
Injuneer Sep 10, 2024 11:40 AM
Noticed you indicated "GB" in your profile, indicating you are in Great Britain, and also that your IP address is from Spain. Do you actually own a 93-95 LT1? If so, we always like to see photos :)
