CamaroZ28.Com Message Board
-   -   OB2 - OBD1 question (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/ob2-obd1-question-428162/)
96m6lt1 Feb 5, 2006 04:40 PM
OB2 - OBD1 question
since obd2 has a crank position sensor and the obd1 does not what if any function does the (CPS) have, is it deleted via obd1?
Dave89IROC Feb 5, 2006 07:50 PM
Re: OB2 - OBD1 question
it plugs the hole in the timing cover..........
96m6lt1 Feb 5, 2006 07:55 PM
so it really does not matter anymore if i convert to obd1 pcm
Birdman7389 Feb 5, 2006 08:05 PM
Misfire detection is waht I was told.
OBDI does not support it, and I dont have one on my car.
shoebox Feb 5, 2006 09:10 PM
There is no provision in the OBD-I PCM to monitor the CPS, so it never knows there is one.
96m6lt1 Feb 6, 2006 02:20 PM
cool thanks for the info guys..
Dave '97 Z28 M6 Feb 6, 2006 10:47 PM
Birdman is right... the CPS is used only for misfire detection, in OBDII.
