o2 sensors
Old Aug 17, 2007 | 10:48 PM
ROUDA's Avatar
o2 sensors
Since I put lts of my 1995 camaro I havent been able to get it to run just rite. I can tell because I can just feel it. I changed the plugs wires gaskets and have been narrowing it down to I spliced the 02 wires so they where long enough. What can o2s do if they are bad or not getting the correct reading.
Old Aug 17, 2007 | 11:03 PM
Faulty O2 sensors or wire extensions can cause the PCM to provide the incorrect A/F ratio = engine lacks power and/or runs poorly.
Old Aug 17, 2007 | 11:04 PM
ROUDA's Avatar
yes that what it does not all the time some times it runs better
Old Aug 17, 2007 | 11:46 PM
tagz's Avatar
How did you go about splicing them? They have to be soldered, and should be the same gauge wire. (i was told that bigger is okay but i'm not positive on that) Butt connectors, or any criimp connectors are no good, resistance is different i believe.. being that it is in millivolts, it doesn't take much to mess up the reading.
Old Aug 18, 2007 | 12:02 AM
ROUDA's Avatar
yea I spliced them in the middle with crimpers that came with the kit. Yes it is millivolts. This is most likely the problem. The hasnt ran rite since I put them on. Could be that.
Old Aug 18, 2007 | 12:26 AM
camarozz95's Avatar
its the splice job same thing happened to me after LT's install....bought new o2's, and got extensions and it ran great after that.
Old Aug 18, 2007 | 12:38 AM
ROUDA's Avatar
I heard something about bosch vette sensors come with a longer wire so you wont need extentions.
Old Aug 18, 2007 | 04:04 AM
v7guy's Avatar
Personally on my 94, I found that one extension was enough. You may try soldering it first as you wouldn't be out much money that way and it's handy for future projects.
At Wal-Mart... don't waste your time with the super cheap soldering iron. Get at least the yellow gun style iron, I believe it $20 or $25. Heat shrink over your connection and use electrical tape over that if you're the extra cautious type.
Old Aug 18, 2007 | 07:41 AM
94_PatriotRed_Z's Avatar
Does it run fine when you first start the car then it will start to run bad/miss when the car heats up? If so it is the o2s, that is what happened when my o2s went bad.
I dont think it is the butt connectors because I made home made extensions, with the end off an old o2 and a new pigtail, and I just butt connected them together, with no problems
Old Aug 18, 2007 | 02:48 PM
ROUDA's Avatar
Will o2 sensors from a ls1 work on a lt1
Old Aug 18, 2007 | 03:27 PM
Razor_Blade's Avatar
LS1 sensors have a different plug.
Old Aug 18, 2007 | 08:36 PM
ROUDA's Avatar
O man I know someone who will give me ls1 o2s for free.
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
