o2 sensors
Old Nov 15, 2005 | 04:59 PM
ruggerz28's Avatar
o2 sensors
the longtubes that i have in my garage do not have any place to put the o2 sensors. I was wondering if i could run with out them or if i have to have them. Also the other option would be to put them in the exhaust y-pipe instead of having to remove the ceramic coating to weld the bungs into the collectors on the headers? any thoughts from u guys?
Old Nov 15, 2005 | 05:02 PM
RE AND CHERYL's Avatar
Re: o2 sensors
Weld bungs into the collectors. It will run good witout them, but gas milliage, throttle response, and drivability would suffer.
Old Nov 15, 2005 | 05:08 PM
BUBBA's Avatar
Re: o2 sensors
You better check to see if you CAN weld them into ceramic coated headers. You might be able to, but it also might require more than just the usual welding: I had to have my egr pipe reoriented to fit my EGR tube on my headers and the welding didn't hold so I had to have the header completely stripped, rewelded and re coated. Just a thought.
Old Nov 17, 2005 | 02:17 AM
ruggerz28's Avatar
Re: o2 sensors
you say gas mileage and driveability will suffer, how much?
Old Nov 17, 2005 | 10:59 AM
MEAN LT1's Avatar
Re: o2 sensors
Its not going to hurt alot but you will notice the decrease. But you should be fien for a while but just amke sure you get them in soon.
Old Nov 17, 2005 | 12:50 PM
NeverEverSatisfied's Avatar
Re: o2 sensors
[QUOTE=BUBBA]You better check to see if you CAN weld them into ceramic coated headers. You might be able to, but it also might require more than just the usual welding: I had to have my egr pipe reoriented to fit my EGR tube on my headers and the welding didn't hold so I had to have the header completely stripped, rewelded and re coated.QUOTE]
Who does your welding then? I weld ceramic headers with out a problem... it is called prepping...
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
