o2 sensor simulators
Ok so i have been having problems with my o2 sensors fouling out and having to be replaced. I was looking into maybe getting some simulators to solve this problem. But, i read that the connector for the front o2 sensors in a four wire flat plug, which is the o2's on my car. I have Pacesetter long tubes,and ory pipe so these are the only 2 sensors on the car. I also read that these control the fuel trims, so they couldn't be simulated out. I was looking to get some insight into this, my car will run good for a while with new o2 sensors and then they will foul out and the car begins to run like crap. Also, do you think just getting a dyno tune will cure this problem?
Thanks Chris |
It is correct that you cannot simulate the front sensors, so that is out. Some research and data from your O2s might help. When you start modding the engine, a tune is often required for it to run it's best.
Originally Posted by shoebox
(Post 6024770)
1996s would have rear O2s as stock.
(Post 6024816)
| All times are GMT -5. The time now is 06:01 AM. |
