o2 sensor issue...
for some reason i just went thru 2 brand new bosch o2 sensors within 2 weeks. what the heck could cause this? :confused:
Re: o2 sensor issue...
Is it the same sensor on the same bank, or did the sensors on both sides fail? Did you just do a header install? If so, the coating on the headers tends to kill 02 sensors during initial startup. Also, another thought, the Bosch sensors have a hit or miss reputation on here. Alot of people have had trouble with them and have had better luck just using the Delco replacements.
How do you know the O2 sensors failed? What were the symptoms?
well it would run fine on a cold start then start idling really bad and burn rich. then the SES light poped on and it ran great. i figured it was the o2s but i wasnt sure cause i replaced both about and it ran alright for a day i belive. so i took it to a shop and they scaned it and he said the passenger side was sticking. that explains why the SES light would go on and off. i did the headers about a year and havnt had a problem till now.:mad: i guess ill try the oem replacements
wait...are there any after market o2's with long enough wires for the LT's?
nope i just used the felpro header gaskets. it was great for about a year.
Do you have the locking header bolts? If not, are the standard bolts snugged down?
bosch are not my first choice for anything |
O2 Simulators:bow: www.jegs.com
what about ngk? those are at summit.
terrible 1: Get the EXACT code that is turning on the SES light. There are several for the O2 sensors, and even though the code description includes the O2 sensors, it does not necessarily mean its the O2 sensor that is causing the problem. The problem may be somewhere else, and affecting the A/F ratio to the extent it sets the O2 sensor code(s). Replacing them without getting the code first was a mistake. |
they guy at tuffys said the passenger side o2 was sticking. i replaced it and it was good for about a week. ps. i was talking about the ngk o2 sensors.
There is no code for an O2 sensor "sticking".
that is all i kno about the scan
| All times are GMT -5. The time now is 09:35 AM. |
