O.D. of the Crank snout????
Old May 2, 2008 | 05:45 PM
jchevy's Avatar
Anyone know what the spec on this is. I bought a crank that was supposed to be from an LT1 but It has a keyed hub on it. I dont have a loose hub to see if I can still use it. So im hoping I can just mic it and see if it matches. Also, does anyone know if they taper or anything like that?
Old May 2, 2008 | 07:50 PM
slowride94z's Avatar
i think same as small block no taper look for one piece seal
Old May 3, 2008 | 08:16 AM
96capricemgr's Avatar
A stock crank has a keyway cut into it just the hub is not cut for the key so none was used. As said the LT1 has the same dimensions as older smallblocks.
Old May 3, 2008 | 05:50 PM
SS RRR's Avatar
One piece is on the left. Two piece on the right.
Jeff1904
Jun 5, 2016 05:00 PM
68camaroboltz
Oct 5, 2015 11:56 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
