Normal burnout lenght from a stop?
Old May 3, 2007 | 09:31 PM
bombebomb's Avatar
Im debateing on if my car has something wrong with it, or im just crazy.
If im completely stopped and I floor it in drive, it cherps the tires a very little bit, then takes off. Is this normal or should I be smokein the tires. I got p235 55r 16's on it good year eagle HR's, rear had something like 30psi, I aired them up to 40 psi today and theres no difference. Is something wrong or am I just used to the car now?
Old May 3, 2007 | 09:39 PM
2.73s won't be aggressive off the line. There are so many variables that might allow/not allow tire spin that it is almost impossible to say what it should do.
Old May 3, 2007 | 09:48 PM
bombebomb's Avatar
Iv tried it in several condictions, still the same unless its raining lol. Maybe im just used to the car, and my 3.73's are hinting at me to put them in. I don't know if I have the correct knowledge or tools to do it, and I dont want to screw up the rear.
Old May 3, 2007 | 09:55 PM
94_firechicken's Avatar
You have an automatic, which I'm guessing is a lot harder to burn out tires than a manual (i.e. cluth drop). Then again, when I step on it just rolling I go sideways... Putting in 3.73's would probably make your tires peel out more, but then again I like to hook with my car imho. I'd expect you'd need more bolt ons and probably a torque converter.
Old May 3, 2007 | 10:00 PM
bombebomb's Avatar
Yes theres no dout I need/want more power and toys, but it seems like it "used" to be more powerful, maybe im just used to it. I'm definently not going sideways if I punch it.
Old May 3, 2007 | 10:04 PM
RyanD's Avatar
back when my car was stock with 2.73's I used to do some sweet burnouts by just flooring it, with good tires too
Old May 3, 2007 | 10:07 PM
bombebomb's Avatar
Flooring it and not turning the wheels? If I turn the wheels I can really start burning, but if im straught, theres no way.
Old May 3, 2007 | 10:28 PM
silver0306's Avatar
What kind of tires do u have? cause when i punch it at a start i spin for quit a while at least 100 ft then it grabs and hits second and starts spining again and i have an auto and gears?? i dont know about but was told they were 273s
Old May 3, 2007 | 10:36 PM
jclark311's Avatar
Hows your compression? My wifes 3.8 burns the tires if you floor it from a dead stop, and its an auto. My LT-1 stick can go for about a 100ft on a clutch drop. If your cam is real worn (which i doubt, because its a roller), or you have low compression, your engine will have ***** from a roll, but not much on the start.
Old May 4, 2007 | 03:16 PM
sn8ke eatr's Avatar
yea i had a stock auto lt1 and it would smoke the tires clear into second. something dosent sound right imo..
Old May 4, 2007 | 03:19 PM
mdacton's Avatar
my old iroc would light em up from a roll and not stop till mid 2nd gear
I know lots of people with LT1's and they all light em up easy
someone gave me a 3.4L firebird.....if you stab it she will peg leg til 2nd
Old May 4, 2007 | 04:14 PM
Jazsun's Avatar
I had a 93 A4 w/ 107k and if the car was straight and I power braked it and stomped on it, it would burn out for maybe 10 yards and hook. It had catback,intake,1.6rr's, cutout. Once of the cylinders was a little low on compression and it burned oil even after replacing valve stems. You probably have low compression, from old rings. W/ my 96 lt1 m6 w/ 35k on it will smoke the **** out of the tires until the 1-2 shift.
I'd do a full tuneup: new plugs/wires/air filter then see if it can light em up.
Old May 4, 2007 | 04:16 PM
Jazsun's Avatar
273's arnt gears, those are stock.
Old May 4, 2007 | 04:21 PM
2000GTP's Avatar
Is the car in good mechanical tune? Is there anything that could be out of sorts that leads you to believe that it is down on power?
Old May 4, 2007 | 04:23 PM
ricehammer's Avatar
You either have real sticky tires, real sticky pavement or your down on torque. Back when my A4 was stock with 2.73's I had no problem igniting the rear tires. Of coarse the tires were cheap, but they had good tread for a little while atleast.
