no start
Old Mar 3, 2008 | 05:16 PM
sn8ke eatr's Avatar
Unhappy no start
well i just did the cam on my car,the cars been down a while now.
when i crank it, it turns over at a decent speed but it sounds like its a little tougher then it should be, the motor kinda sputters and pops a little but wont fire up, its almost like if a distributer were to be in backwards on an old style sbc.
anybody got an idea? im kinda lost here.. i cant seem to figure out what the problem is, could i have not lined up the opti? im just about positive that the timing gears are lined up, i thought of that. any other plugs.wires that'd cause this?
Old Mar 3, 2008 | 05:23 PM
MEAN LT1's Avatar
Check your alignment with the opti and make sure its in there correctly.
Old Mar 3, 2008 | 06:45 PM
93transam1234's Avatar
Agreed, tons of people on here put the opti on wrong and get a no start.
Pull it off and double check it, Also this would be a good time to double check you plug wire routing and timeing set.
Also might want to check you dowl pin length (do a search for that one)
Old Mar 3, 2008 | 09:50 PM
sn8ke eatr's Avatar
cool guys i appreciate it and the more i think about it i was rushing to get the opti on.
wires i know are good because i clearly numbered them, and dowl pin i looked into thoroughly. thanks for the help so far, if anyones got another idea shoot.. ill try em all out tomorrow.
silvermansteve
Mar 4, 2015 05:02 PM
eazyZ
Mar 1, 2015 07:12 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
