no start
Hi, thought I had egr problems ,now my 96 m6 will not start ,I have power,but it will not spin at all, I can hear pump prime ,but it seems like a heavy click noise near trunk open button, when key is turned to start,Thanks ,Baffled
Re: no start
if the clicking seems odd to u then try replacing that first and c if thats ur problem
find out of the car is getting either fuel or spark , u need both to start hehe
does the motor turn over at all , any clicking sounds when trying to crank
check ur battery and power going to the starter
Re: no start
Check battery terminals if everything on the DASH goes out when trying to start, if not then check maybe your VATS if flashing and you have a bad key or key cylinder. Then try tapping the starter with a hammer lightly.
Alex Barnes
Jan 24, 2015 10:21 PM
