no start
no start
on my buddies 95Z there is now power being sent to the purple solenoid wire on the starter. When you turn the ignition to the crank position the radio turns off and acts like it is working, and the clutch switch is good. the secruity light goes on then comes off. WHat else can I test or look at? what wire under the dash should I check to see if its getting power when the ignition is in crank position.
any help would be appreciated
Re: no start
If the security light even comes on at all, that means the TDM is shutting off the signal to the TDR. If your stuck for use of the vehicle, jump the yellow to the purple wire on the TDR. Be careful, the engine will start whether you have the clutch in or not and even if it's in gear.
You can also eliminate the key and it's contacts being the problem by putting a resistor in the orange wrapped harness at the base of the steering column. Get a resistor the same value as the key pellet. Put it in the harness side going away from steering column. If the resistor helps, the problem is either the contacts in the cylinder or the key or a combination of both. I did the resistor thing about 2 years ago and eliminated all the problems.
Alex Barnes
Jan 24, 2015 10:21 PM
