no screen maf sensor
Hey guys I was cleaning out the camaro n found a box which has the two ends that hold the maf sensor together but no screen,the invoice has the previous owners name on it,i believe he was gonna use it for performance wise.
I researched about no screen maf sensor,I'm getting different results of ppls opinion,but wanted to see what u guys think. Thanks guys. 94 Chevy lt1 camaro z28 pretty much all mods that are common and bolt ons,bigger cam, all suspention etc. |
Re: no screen maf sensor
the screen has a purpose..it "stabilizes" the air going across the wire sensors giving a more "accurate & stable" reading of the MAF function to PCM
keep it on. |
You don't need new ends on a 94 to delete the screen. The screen is held in by a snap ring and is removable.
Leave it in there, for the reasons explained above. |
Ok thanks guys I appreciate information about that
Hey guys one thing I noticed that the coupling between the end of the maf sensor n my kn air filter the coupling that's inserted the maf sensor it's not the correct size I can't insert it all the way in,i looked at it bcuz in the 3rd gear my camaro is like jerking n hesitating,I'm not hearing misfire or popping.
but I just need to make sure it's called a coupling to hold the maf n end of the kn air filter |
https://www.google.com/search?q=lt1+coupling+for+maf+sensor&prmd=sivn&sou rce=lnms&tbm=isch&sa=X&ved=0ahUKEwj2l-HaqYDWAhUMyWMKHXZwD0sQ_AUICygC&biw=320&bih=486#img rc=mgnKVponwrcJzM:
Here's a pic of what i need |
Your link shows hundreds of different things.
Is the K&N a recent purchase? If so, is appears they are including a filler piece for the non-MAF 1993 cars, and making it a 1993-1997 kit. The filler piece on the end is not used on 1994-97 cars.
https://www.jegs.com/images/photos/5...-57-3010-1.jpg If that is not the problem you are having, try explaining it again, because what you wrote in post #5 is unclear. ....the coupling that's inserted the maf sensor it's not the correct size I can't insert it all the way in, If so, what is the outside diameter of the MAF senor end? What is the inside diameter of the short rubber coupling? |
OP
a picture of "your" MAF/intake connection issue will be helpful for any of us to better understand WTF your issue is.. Nothing goes "inside" the MAF...it should clamp on the outside, both ends |
If what you need is a coupling between the MAF and K&N, go to your home supply store and get a Fernco rubber sewer pipe coupling of the correct size. Warm it in some hot water to make it pliable.
[QUOTE=shoebox;6994589]Your link shows hundreds of different things.[/QUOTE
hey Rob sorry,and Fred too,i fixed the couple I cut it down to get the maf sensor inside so that it doesn't keep slipping out,no it wasn't a recent purchase I believe the previous owner ordered the wrong one for the camaro |
Originally Posted by Chimera96
(Post 6994592)
OP
Originally Posted by 94Z28LS1toLT1
(Post 6994601)
,so me as a Christian I'd appreciate it if u don't use the wtf and be patient with ppl,we are all on a team on this website to help each other out!!!! And not say insulting things to each other please. God bless you sir.....
It sounds like you have resolved your issue and Fred or Robs advice is always gracious and spot on Good luck |
(Post 6994603)
Apologies if you felt any offense, personal or otherwise. My abbreviation was referring to your intake/MAF connection, certainly not you.
| All times are GMT -5. The time now is 05:02 AM. |
