New times since my last outing over four years ago.
I took my car to the track today.
I went knowing I would be short shifting and not using my t-brake but I wanted to see what it would run...basically I have been tired of fixing stuff and never running the car.
On this run I shifted @ 6000 rpm (I am working on my ignition issue), launched @ 1800 rpm and there was an 8-10 mph headwind . It was breaking up going thru the traps.
Times:
60' - 1.5802
330' - 4.5613
594' - 6.6140
660' - 7.0763 @ 97.34
1000' - 9.2170
1320' - 11.0811 @ 123.01
Should be quicker when I get the ignition issued resolved and leave on the t-brake.
Times:
60' - 1.5802
330' - 4.5613
594' - 6.6140
1000' - 9.2170
I figure mid 10's on the stock PCM.
I have a F.A.S.T. system on the way and once I dyno the car with the rpm miss gone I will have an ideal of where I should shift and if the system should go on before my twin turbo combo.
The car I raced was an mid 80's Monte Carlo...Regal...along those lines.
At about 6200 rpm it was just breaking up something fierce so when the tach hit 6000 rpm I was shifting.
The only item I never replaced in the ignition is the stock opti-spark. Even though the Delteq eliminates the opti-spark somewhat, it still uses the optical sensor which itself is not prone to failure...but the bearings that house the sensor have been known to fail.
I also believe this might be causing my timing issues....I do not know what timing I have.
How about a quick rundown of the combo for us. I remember a long long time ago you talking about a 396 i think. Looks like it runs real strong that mph is great for the conditions you described, good work
block
396" LT4 block with Milodon billet mains
12.2:1 compression
3.875" Dragonslayer crank
5.850" Lunati pro mod rods
Diamond pistons
Canton oil pan
Heads/intake
AFR 210
LT4 intake
solid roller cam
stud girdle setup
Exhaust
Kooks headers
3" dual pre axle dumps
BMR & Spohn suspension parts.
a-arms (upper and lower)
k-member
KBDD subframe
lca's
panhard
custom torque arm
Moser 12 bolt 4.10's 33 spline, c-clip elims
Denny's nitrous driveshaft
TH-400 with t-brake
Neal Chance tq
Most boltons also.
12.2:1 compression
Diamond pistons
Canton oil pan
Heads/intake
AFR 210
LT4 intake
solid roller cam
stud girdle setup
Exhaust
Kooks headers
k-member
KBDD subframe
lca's
panhard
custom torque arm
TH-400 with t-brake
Neal Chance tq
Most boltons also.
Other than that I'm jealous.
