CamaroZ28.Com Message Board
-   -   New lifters with cam install needed?? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/new-lifters-cam-install-needed-200049/)
Xride Dec 4, 2003 09:34 PM
I was thinking, to save a bit on my cam install how importand are new lifters?
cause stock there is already hydrolic holler lifters isnt there??
S.J.S. Dec 4, 2003 09:39 PM
No!.... someone just asked that. check on this or the next page.
formula383 Dec 4, 2003 09:41 PM
I would go ahead and change them while you are tore into the engine.
JKDZ28 Dec 4, 2003 09:47 PM
change the lifters... im doing so
Xride Dec 4, 2003 10:26 PM
I cant find where someone else asked, sorry, I even searched. couldnt find what I needed.
I know its a good idea while I'm in there, but how good are the stockers?
I'm going with a cc306, and only have 60000km (30000 miles) on my car.
Larnach Dec 4, 2003 10:28 PM
I was advised by CM when I did my heads and cam that it is not needed, they could have made some extra money but they said dunk them in oil and check the plungers.
I'll trust em.
93formula Dec 4, 2003 10:37 PM
doesnt the cc306 like to rev to 7 k? id personally want to pick up some comp r's if i were reving that high.
Larnach Dec 5, 2003 07:40 AM
In a hydraulic roller setup, reaching 7000rpm isn't just your pistons. You need a rev kit that will force pressure down on the lifter bodies to prevent valve float. Let alone the $$$ in lightweight valvetrain components.
Don 97 SS Dec 5, 2003 12:09 PM
New lifters are not required, but I believe it is advisable to replace the lifters. They are a wear item and since you are that far into the engine it just makes sense to install a fresh set. While I am sure there are several cases where a used set went another 50k miles after a new cam was installed, I'll bet there are many more where they are crying and wishing they had. ;)
