New Head Gaskets and heads redone, Still smoking...
Subscribe
Sep 2, 2011 | 01:01 AM
Had heads reworked and milled. Put back on the car with all the right specs. Started car and within 5 minutes was blowing white smoke. Dont get it. New head gaskets, reworked heads... It runs smooth, just smoking.
Any ideas?
Reply
Sep 2, 2011 | 01:07 AM
Re: New Head Gaskets and heads redone, Still smoking...
Sorry this doesn't answer your question but make sure you get your coolant flushed out and replaced (Dex-cool). You might get some oil in your coolant after any headwork so pull out your coolant dipstick and check it out.
Reply
Sep 2, 2011 | 01:59 AM
try running some seafoam through it if that don't work check your piston rings...
Reply
Sep 2, 2011 | 06:44 AM
Depending on how bad the original condition was, there may be some coolant still in the exhaust system that needs to be burned out.
Reply
Sep 2, 2011 | 01:50 PM
Have you done a compression and leakdown test on the engine(pointing to the rings like the gentleman above)? How long did you run the engine after the smoke started?
How many miles on the bottom end and has it had a rebuild?
Reply
Sep 2, 2011 | 03:27 PM
Quote: Depending on how bad the original condition was, there may be some coolant still in the exhaust system that needs to be burned out.
This would be my initial thought as well.
Reply
Subscribe
