new engine first start codes?
Old Oct 13, 2010 | 09:29 PM
z28beast's Avatar
27-egr elec. fault qdm
26-quad drvr mod 1 fault
66-a/c pressure sensor
77-fan 1 fault
53-system volt too high
51-ecm prom error
91-1-4 lamp circut
ok well i know that the ac and egr codes are on because i removed them both. are the rest because i put an oversize cam in ? do you guys think that a tune from pcm for less will fix these? i do have the lt4 km in if that makes a difference.... can anyone give me a description of whats causing these? im hoping the tune will fix these codes
Old Oct 13, 2010 | 10:11 PM
Clear the codes, see what comes back. Use the code list link in my sig. Most of the things you left off are going to have to be programmed out.
Old Oct 13, 2010 | 10:32 PM
z28beast's Avatar
thanks for the info shoebox...i appreciate it. the only thing that concerns me is 53 system voltage high. any idea what could cause this? also in your honest opinion do you think that pcmforless is a good source to get the pcm tuned?
Old Oct 14, 2010 | 04:52 AM
RamAir95TA's Avatar
PCMforless.com tuned my car, both mail-order and on the dyno. I'd say the results are acceptable.
HCz28
Jan 11, 2015 11:21 AM
Dec 1, 2014 08:08 AM
Jul 4, 2005 05:00 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
jrp4uc
Jun 19, 2002 06:20 PM
