never heard of anything like this before
Old Oct 29, 2007 | 03:01 PM
  #31
ThunderboltZ28's Avatar
Originally Posted by White96Z28
Well go buy an alternator then and see if it fixes your problem.... You need to charge your battery up fully and then swap the alternator and see what happens.
I agree with some of the other guys and think you lost the rotor in your opti though... I think when you downshifted it put a load on the motor and the rotor came loose. Can you hear any scraping noises or anything coming from the distributor area?
no there isnt a scraping noise...and the thing is ive just heard it's called powershifting when you downshift an automatic..im wrong about that...i was seriously only going about 30...wasnt revving up the engine or anything...just shifting down is all..i just wanted to coast in second cause it was on a a back road...i dont think doing that damaged anything..my friend has a heavily modded mustang and it's an automatic...he HAS to drive it like manual because the transmission slips when he has it in regular drive...like he'll start out in 1st gear then shift to second then drive..it's kinda funny really but yea he does it all the time and it hasnt done anything to his engine that i know of
Old Oct 29, 2007 | 04:16 PM
  #32
2QUIK6's Avatar
For your buddy in the stang, if the tranny is slipping when it shifts normally, then its slipping even more when he's manually shifting it, its just the rpms are higher so it "feels" like its slipping less, putting even more heat in the tranny, it won't last My guess is he feels cool by shifting it this way since he drives a stang
Old Dec 12, 2007 | 10:32 PM
  #33
RicFusion's Avatar
I had this same issue several times with several different Models of chevy. One was on a 99 Cavalier, when we were syphoning the gas out so we could replace the fuel pump, we noticed some sludge in the tank, and the same sludge in the filter. Replace them both and cleaned the tank. Ran fine after that. Also have a 95 firebird, for it, I had a friend replace the waterpump for me, and when he did, he forgot to plug the coil pack back on it, so check your coil pack too.
autoxr166
Sep 25, 2015 04:21 PM
colts0455
Sep 22, 2015 02:03 PM
karpetcm
Sep 15, 2015 11:07 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
colts0455
Sep 4, 2015 01:41 PM
