neutral safety switch
Anyone changed a neutral safety switch on a 94 camaro? If so would you happen to have directions or pictures.
Re: neutral safety switch
any body???????? the car has a new battery, starter, alternator and only starts sometimes. we are running out of things to change
It's going to be at the base of the shift lever in the console. Shouldn't be too hard to figure out how to replace or to test it. Actually, a scanner will tell you if it is working or not.
