CamaroZ28.Com Message Board
-   -   needsome help bad!!!!!!!!! (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/needsome-help-bad-314758/)
sdowney Nov 2, 2004 11:22 PM
i have a miss trhat i can not get rid of. i do not know what else to do i have researched it everywhere and have done everything i have found that might cause the problem. started with plugs and wires,optispark,timing chain. it finaly set the check engine light off last night so i will check to see what the code is tommorow i finaly go t my cord so i can connect to the computer with my laptop. i know other people have had this problem has any one found the answer to this mystery problem yet? i have not been here in a long time i have been busy with my new c6 corvette but i still love my trans am i just widh it ran as good as it did when i start it all the time. it is very frustrating to have spent this much money and still not be right!
ford Nov 3, 2004 09:44 AM
Re: needsome help bad!!!!!!!!!
Explain the miss, where in the rpms you get it at and is it at WOT or not.
Have you tried the coil yet??
The more info i have the better i can help you.
