need some help with my setup
Old May 13, 2004 | 04:04 PM
BlackbirdWS6's Avatar
I have a 97 TA vert and just ordered Hooker LT's, now i know i gotta extend the O2 sensor wires but which type of connector is it since they sell O2 extensions but in two different plug types? Next, I will no doubt have to get O2 sims for the rear ones in order to not pop a code, is this also correct? Lastly, is there a difference in long tubes for a vert than a t-top car? I wouldnt think so but i need to make sure of course. thanks
Old May 13, 2004 | 04:23 PM
madwolf's Avatar
You need two 24" extensions for the front o2s. (4 pin flat connector as opposed to square for rear o2s) You will either need to get two o2 simulators for the rear o2s or get them programmed out.
There are no special convertible car headers.
Old May 13, 2004 | 05:30 PM
Somnambulist's Avatar
two 24 or two 12?
Old May 13, 2004 | 06:31 PM
thanks for the info, but to clarify...i need just the (2) 24 inch extensions and O2 sims correct? I do not need extensions for the rear O2 which will be replaced by the sims? just making sure so i can order the stuff now. thanks again
Old May 13, 2004 | 06:54 PM
madwolf's Avatar
(2) 24" extensions for the front o2s, yes. The sims will connect directly to the rear o2 connectors.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
FryedClutch
Sep 1, 2015 08:24 AM
detroitmuscle
Jul 31, 2015 04:21 AM
