Need Part # for LT4 intake gasket
From: Albuquerque,NM--5,600 feet above you sea-level cats
I'm running AFR 210's and a LT4 intake. I used a regular LT1 gasket when putting the motor together. The Stock type gasket does come down into the ports which I know hurts the flow alittle bit, but know and car is sucking oil, and I think this is why. Upon hard accelration, and letting off, I can smell oil right away. When I pull the plugs, they are all black coated with oil. Looks like it's baked on. I'm hoping the gasket is the problem and would like to get the right one one this thing.
Also, I'm running head studs. Is it possible to pull the heads off with studs????
Neal
Neal
Re: Need Part # for LT4 intake gasket
Originally posted by PNYKILR
I'm running AFR 210's and a LT4 intake. I used a regular LT1 gasket when putting the motor together. The Stock type gasket does come down into the ports...
Re: Re: Need Part # for LT4 intake gasket
Originally posted by arnie
I trust, you are referring to the ports, in the manifold, in your statement above, regarding 'gasket comes down into ports'. Or, are the manifold ports unmodified?
